Hi, ive just recieved my black fascia which i bought off ebay to replace the silver one on the nokia n80, i have no idea how to take the old one off, i have taken the 2 screws out at the top, but i cant get the cover off i feel like if i force it, it will snap, does anyone know how to do it or know a place where i could get instructions from, id really appreciate it, dont wanna break my new phone 😮 cheers.
N80 change facia instructions
hey jada,
try this link, took me ages to find some decent instructions
http://web.mac.com/the_reamer/iWeb/f...DAEF72CB4.html
try this link for details of removing case, dropped mine last week and its well stratched & dented, bought new facia off ebay, waiting for it to turn up. looks esay enought thou, but i would expect it invalidates ur warranty etc
will let you know how i got on!!
dean
Hey thanks for that, and yeh let me know how u get on 😊
will do mate, my facia came today so trying to get my hands on a torq 6 driver so i can operate, hopefully i wont completely knacker it up, if you manage to get it done this evening give us a shout as to how easy/nightmare it was
[email][email protected][/email]
good luck!!!!!!!!!!!!!
Hiya, ive just managed to do mine, my case came with the torx screwdriver, all i did was take out the screws, then get a thin flat headed screwdriver and carefully run it along both sides, then it comes apart, if i managed it then anyone can lol, it is quite easy as long as you are careful 😉 hope that helped a lil.
that was quick, well done!! there must be hope for us all then ; )
Dear friend, It�s possible to put the video again ... :redface: .. I could change the fascia, but not the keypad ... thanks.
