Adding Apps to Go To Menu
5 replies · 1,564 views · Started 02 August 2006
Hi
New N70 user here and so far, it's been great.
But i've been searching thru the manual and thru the forums as well and can't find a way to add installed apps to the Go To menu.
Any suggestions??
To add, use the options in each aplication. Some of them, let you do a "add", others don�t. Or use a dedicated program, that can do that, like Handy System.
yeah i knew about that but most applications don't have the 'add to go to' option so no point to that.
Searched for the Handy System but couldn't find it. found a bunch of other handy software tho.
Do u wanna confirm the name or send me a link?
Maybe you are right... I don�t remenber well... Is something like handy System or System Tools... one of the options is add to "Go To " menu!
pls let me know the name when u find out, or if anyone else knows. tried searching the shop and google for possible names but no luck as i don't really know what i should search for.
would appreciate it if u could be a bit more helpful
