okay this is kind of about my n80 (Wifi) right now i have 3 computers (desktops not laptops) and my network is all with cable router, i need to get a wireless router so my wifi on my n80 works at home, but my question is that what will i need to connect 3 of my desktops together and beable to use my wifi on the n80.
Kyle.
You could just plug a simple wireless access point into your router and leave everything else as it is. i.e. just use wifi on the N80
can how would i do that? do i have to buy something that goes into my router? and if so what would it be?, sorry about these dumb questions but its first time for me going wireless lol.:tongue:
Yea you need a wireless router for your n80, and your desktop pcs can connect to the wireless router via ethernet cables (like a big phone line). Most wireless routers ive seen have 4 ethernet outlets. or you can get a wireless adapter for each pc. Mite cost a bit though if you have to buy 2 or 3 of those.
concidering all my computers are already connected with ethernet cables all i need to do is switch my router with a wireless one?
killah_thug08 wrote:concidering all my computers are already connected with ethernet cables all i need to do is switch my router with a wireless one?
There's not much price difference between adding a wireless access point to your existing router or replacing it with a wireless router with ethernet ports. The replacement option removes the need for another socket and keeps the number of boxes with flashing lights to a minimum.
A couple of quick points to bear in mind if looking for a wireless router. Get one with B & G support, built in security (firewall), WPA-TKIP support, MAC authentication support and twin aerials (better signal) as a minimum. UPnP support is a must if you want to use it with your N80 (for future proofing if nothing else). Configure it to use WPA-TKIP, MAC authentication and not to broadcast the SSID as a minimum.
NB: The type you require will depend on whether you have a cable modem or ADSL - I'm speaking from a cable modem point of view below..
I've installed a lot of Linksys WRT54GS wireless routers for family and friends and use one at home for my 4MB cable connection with with 3 PCs, a Buffalo Home Media Server and my N80. Works well enough - no reboots since installing it a year ago - and seems a lot more reliable than other ones I've had in the past. Signal strength is good (passes through 3 external walls into the garage at the end of the garden without issue.
NB: If you go for a WRT54GS get a v4 revision - avoid the v5 as it's been neutered (reduced RAM and other resources).
HTH
so would you do me a favor??
in futureshop.ca if you had to pick the best wireless router there which has all those things you said which would u pick?
Kyle.
THANKs
I'd don't know whether you'll be using a cable modem or ADSL..
I can only really advise from cable modem experience, in which case http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10043626&catid=19994
assuming it's pre-v4 revision of the hardware.
Apparently UK and US have different versions of the hardware, and your v4 was the neutered one according to the consumer reviews..
HTH
