this probably is off topic, but here it goes anyway, im looking for any midi program that amplifies the instruments played, so it plays louder when sent to the 7650
midi amplifier
I think there is a program for the 7650 called ringtone studio that might do that! I havent tried it yet! I think its from wildpalm! S check there for a trial!
http://www.wildpalm.co.uk/7650.html
well i'm using ringtone studio too on my phone but i can't seem to see the diff'rence of the loudness of the midi's when playing! i don't know you should try it!!
Can't you open the midi files in some sound editing software? Like soundforge...
There you can do everything with it.. including volumecontrol.
[quote="Shadow"]well i'm using ringtone studio too on my phone but i can't seem to see the diff'rence of the loudness of the midi's when playing! i don't know you should try it!![/quote]
well it works well for me..what i do is open a midi file then edit song then change volume and set it at 200% ..have fun!
oops sorry forgot to log-in.. 😮ops:
that ringtone studio sure is a nifty program, now if only i could raise $10 so i could actually use it.... oh well, time to break the piggy bank... d'oh, they only accept credit cards..... sigh....😞 hey!!! i gots an idea, could somebody amp the ketchup song and post it here??? please??? 😃 😃 😃 oh, and also try to trim the 3 second silence at the beginning 😃 😃 😃
Oh I have an idea! Buy the app or use one on your PC!
thanks thanks😊
[quote="paloyme"]thanks thanks😊[/quote]
you can use Anvil Studio to edit the tone. but i dont think you can amplify the sound. it's fairly easy to use. do a google search and you'll find the link, the trial version will do.
