Anybody else having problems with......
6 replies · 1,383 views · Started 02 December 2002
PC Suite and Windows XP?
I just cant get it to work properly. For me to transfer files and ringtones via Bluetooth i have to use Network Neighbour hood and drag and drop.
Thanks in Advance.....
Great forum btw 😉
i think for windows XP
u need to remove the Service pack no 1
but let's just wait till the expert comes
:angel: :angel: :angel: :angel: :angel:
i have no problems when using pc suite and xp.
once the devices are paired, i double click the mRouter icon in the sys tray, i uncheck bluetooth com3, then i check it again, then i get a message on my phone, i press accept, then shortly after (about 3 - 4 secs) the mrouter starts connecting (u should see it animate in the sys tray). once its connected i open up pc suite and i can do what i want with it.
anywayz its 1:30am here so im off to bed, nite!
hope i helped.
**** if u have set ur bt options on the phone to authorised u will not get a message on ur phone when its trying to connect ****
[quote="Nightfly"]i think for windows XP
:angel: :angel: :angel: :angel: :angel:[/quote]
i use service pack1 and everything works perfectly.
anywayz im off to bed now
[quote="555"][quote="Nightfly"]i think for windows XP
anywayz im off to bed now[/quote]
nahhh... this is why i said wait till the expert comes 😃 😃 😃 😃
[quote="Sp00ky"]
Great forum btw 😉[/quote]
Well, to transfer any kind of files other than images, u WILL have to use Bluetooth neighbourhood. So u are on track, unless i missed something here
