Problem installing app
2 replies · 3,238 views · Started 03 August 2006
😮 Hi
I used a trail version of an app (nutracheck) which installed with no problems, it was pushed by WAP form the website. I then upgraded to the full version and uninstalled the trial, which appears to have uninstalled correctly.
Now when I try to install the full version also pushed by WAP it connects to the web then says installer then fails with an Error Msg 'Unable to install invalid file format'
They resent the link and it still failed. Their Tech support is looking at it as well but wondered if anybody here had any ideas.
If possible, try install the first one again, and uninstall. After that, install de second one.
Thanks for the reply,
I would have to get them to send the link again for the trail version as Ii deleted it, but I will try it.
