I just buyed a 1gb card, but when i enter it what must i do. i copyed all the stuff from my old one but it dosent show up in gallery, but the music files are there.
Allso now after much in and out and back and forwared the card sayes max capasity 436mb and not 965mb like it was at first.
Format the card inside the phone. After that copy the files you want (mp3, jpg...) to the new card.
I first insert it and then i copyed stuff inn and it didnt work.
Then it got some wiered symbols on the file names and i cuddent formate it.
I restarted it and i then formated it from the computer.
Then i tryed starting it with out any thing on it, it auto made some folders but it didt save pictures
then i formated it again and try copy again and same problem and whne connected again the image folder was gone.
then i did this back and forwaed a couple of times, but still same resultate.
Then i formated it from the phone and when i looked at it at the computer i noticed that it was only capsity of 436mb and not 956 or soimething like that.
I formated sevral times from the phone and computer but still no go, and still no back to normal capasity.
Sorry for bad english
Ok i can save the pictures now.
But now the only problem is way is it half capasity and how can i get it back to 1gb
Wait to know if the card is correct! Is a slow card?
Its a 1gb card not fake.
Its twinmos MiniSD 66X ultra 1gb
It was 956mb at some point before it droped to 456mb, droped while i was messing around with it to get it to work.
Edit: Ok now i tryed search for my music files i put in and it freezed at the music libary. And i whent back on the computer and looked and the memory card was emty again and no pictures either there in gallery
Can You format the card in another phone?
