Is there any application avaliable which will allow my Nokia E70 to view my LAN? i want to stream some mp3's off my PC to phone via wifi
Nokia E70 seeing a LAN?
The E70 has built in WLAN/WiFi, so all you need is a WLAN/WiFi router on your home network (or a WLAN card in your PC).
Then you can run a web server on the PC (or you could go with something like Orb: http://www.orb.com).
N/A wrote:The E70 has built in WLAN/WiFi, so all you need is a WLAN/WiFi router on your home network (or a WLAN card in your PC).Then you can run a web server on the PC (or you could go with something like Orb: http://www.orb.com).
what exactly do you mean by a web server? you mean hosting a website?
Wirelessly posted (Nokia E61: Mozilla/5.0 (SymbianOS/9.1; U; en-us) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
You would have to run some sort of server service on your network in order to access files on the network. A web server is probably the only workable solution, but I don't know how you could make playlist on a plain web server though.
Streaming music probably rewuires a lot more than basic http hosting, I am not sure it is worth it.
The N80 is made for such a thing with UnPP.
regards, Michael
regards, Michael
gnump3d is a pretty good music server, it works on windows but you need to install perl first. There are instructions.
