Thanks to blkcliostu's post about the hidden GPS app,
I found a Video Editing app, which is actually quite good for a mobile! (Not the Muvee thing that automatically makes videos)
Im not sure if its just hidden on my Vodafone N80, but ive never been able to access it before!
(You need Best Taskman)
under taskman-->misc--->options--->show hidden apps & show all preinstalled files...
then go to the "installed" function, scroll upwards to reach the bottom of the list, and you should see Video Editor.
Once in it, you can stitch multiple videos together, cut bits out, add effects and transistions etc... Much better than that Muvee crap.
