impossible to write on drive z, but...
4 replies · 2,086 views · Started 02 December 2002
i know that this is impossible, but when i change the wke-up sound with eprofiles and turn my phone off it still works...
im just interessted how this can work, cause when my phone is off it cant have any apps running, right??
or maybe i just dont get it 😊
thx, tias
Not sure exactly what you're trying to get at, though when the phone is off, it does have a minimum set of apps running. How else does it know to turn the phone on when you press the power button, or how does it keep track of time if this weren't the case? 😉
You dont have to write do drive z: to do that,you just need some programing skills to code a workaround,i guess that psiloc did that with eProfiles.
not recommended though. i've had three new 7650's in the last week because i've been messing with files on the Z: drive. there are a few basic things you could do like renaming but thats about it.
(wouldn't it be great if you could use the 16mb on the Z: drive to install data) 😊
