i have recently buy a n80, V 3.0614.0.3. i have installed theme on phone memory but when i want to delete it, i cant find the file to unistall the theme! where can i find the file for deleting..?
and another problem is i using 1GB kingston mini sd, it sometimes freeze when i open the gallery..how to solve this?
thanks very much for the help! u may email me at [email][email protected][/email] for the solution..thanks alots!
to uninstall theme, all you should need to do is;
menu, tools, applicaation manager, highlight and then options and delete!!
are you in uk? if so you may want to get upto date firmware
v 3.0617.0.6
03-05-2006
rm-92
this should iron a few irritatting bugs, still far from perfect thou....
as far as ur card, i'm not sure, i am running a 1gb sanddisk and that seems fine, got it off ebay months ago for about £25, you can get a 2gb for about that now. i have heard that there are some fakes ones on ebay thou so need to check feedback n all that before you commit, try saving the contents of ur card to ur pc, format the card, and copy everything back..
hope this is of some help
Deano
there is no files for the theme in the application manager..that's the problem..and now my phone memory only left 1mb.. 😞 i heard that there are a lot of problems in n80 for the memory card..
i think you go to themes, choose the theme you dont want and pick delete from there?
i cant delete from the theme section. when i pressed 'C', nothing happens..so..anyone knows how can i delete my theme which is install in my phone memory?? please help...thanks..
