I really like some of the original ringtones and would like to use them else where.
Like the whistle one. I'd like to use it on my PC for email notification.
Is there anyway I can transfer it to my pc?
Laurie
Can i transfer original tones?
No. ROM files can�t be edit, copy, change, nothing.
yes u can, email me at [email][email protected][/email] i have a file explorer app and u can copy the tones from the ROM (Z😊 drive and then send them over bluetooth etc!
Your default ringtones are restricted content and are stored in rom and can not be seen by the built in file system
However if you install Y-Browser - see thread
http://www.3g.co.uk/3GForum//forum/thread/42126/
then browse to the Z:/Data/Sounds/Digital/
You will find your ringtones, select the one you wish to send and click Options/File/Send
you will then be given the option to send via Bluetooth/MMS/Email or Infared, havan't tried the other options yet but they send via bluetooth just fine.
Ratkat wrote:Your default ringtones are restricted content and are stored in rom and can not be seen by the built in file systemHowever if you install Y-Browser - see thread
Y-Browser? ROM files?
ratkat is correct, thats the app i was gonna send via email!
Biggzy wrote:ratkat is correct, thats the app i was gonna send via email!
What else can be donne with Y-Browser, different from FExplorer?
brilliant thanks all
I used Y-Browser to Copy it from Z: and paste it into E:/
then browsed the phone using my PC and copied it.
Thanks!!! Brilliant program
Laurie
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
my pleasure, anything to help!
