free games and applications
7 replies · 2,568 views · Started 05 August 2006
put it this way, you dont have to pay for them, donwload the files to ur pc, un zip, copy to your memory card and install, job done!!!!
anybody elses n80 take ages to install java games if you install them from the phone itself? (rather than via pc suite and data cable?)
i install them on the fone, set up a folder called games on ur card, connect card to usb, select data transfer, drag and drop into folder, then disconn usb, goto file manager, find ur folder and open from there, there auto install (one by one) takes no more than 15 secs per game, i find the installer a bit tempremental
Where as I just slected open straight from the website link, downloaded, and installed over b/t in no time at all
