I have a Nokia 6630 running TomTom Mobile Version 5 (419) GPS Driver v1.20
I have a BT GPS Ver 1.5 (Fuzion)
I am having problems connecting to the GPS, if I use the phone ..Connectivity...Bluetooth...On..It will not
communicate with the GPS....However it still finds it ???
If I open Tomtom, then go to"Show GPS Status" and connect that way it works if I select "Other Bluetooth GPS"
And choose "BT GPS" it will connect, it just seems a long winded exercise to enable the GPS receiver.
Is there a GPS fix/patch that will solve this problem.
Thank You.
