hello,
i'm stuck with getting my e60 online and i can't find the solution.
I can set up an access point by searching automatically for WLAN as long as the AP-mode is set to Ad-Hoc (iwconfig ra0 mode ad-hoc).
Infrastructure isn't found though i saw plenty of Infrastructure-WLANs
with the phone and was able to use the free ones.
As far as i see through it the wlan-card and the e60 do exchange packets (RX/TX) and also the connection is made (the four window(s)-like squares are filled out). but the browser (built-in one or opera) doesn't get over contacting.
in the active connections (e60) i can see the 28-byte-wise rising Sent-statisitics, but the reply is missing. i can even see the packets coming on my ra0-device (ifconfig ra0 -> RX bytes) of course without transmission following (TX bytes). what is missing in my routing table?
here my other relevant setup:
the "advanced connection settings" (which were uneasy to find) are:
IPv4 settings:
phone ip: 192.168.202.1
subnet mask: 255.255.255.0 (tried also 255.255.0.0)
default gateway: 192.168.200.1
dns address(es): both ones of my ISP (both online of course)
{IPv6 settings: well-known}
Ad-Hoc channel: 7
my WLAN-card gives:
#ifconfig ra0
ra0 Protokoll:Ethernet Hardware Adresse 00:08:A1:94😃F:AB
inet Adresse:192.168.200.2 Bcast:192.168.200.255 Maske:255.255.255.0
inet6 Adresse: fe80::208:a1ff:fe94:dfab/64 G�ltigkeitsbereich:Verbindung
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3365 errors:0 dropped:0 overruns:0 frame:0
TX packets:348 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenl�nge:1000
RX bytes:247786 (241.9 KiB) TX bytes:0 (0.0 b)
Interrupt:10 Basisadresse:0xd000
#iwconfig ra0
ra0 RT61 Wireless ESSID:""
Mode:Ad-Hoc Channel:7 Cell: 22:57:35:BF:0C😃4
Bit Rate=11 Mb/s
RTS thr😮ff Fragment thr😮ff
Encryption key😮ff
Link Quality=69/100 Signal level:-70 dBm Noise level:-111 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
and my routing table looks like:
#route -n
Kernel IP Routentabelle
Ziel Router Genmask Flags Metric Ref Use Iface
192.168.201.0 0.0.0.0 255.255.255.0 U 0 0 0 eth1
192.168.200.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.202.0 0.0.0.0 255.255.255.0 U 0 0 0 ra0
0.0.0.0 0.0.0.0 0.0.0.0 U 0 0 0 ppp0
(ppp0 is my dsl-conn., eth1 is connected with the cable modem, eth0 is on the local network and ra0 is a noname-card with the RaLink/RT61-chipset)
can someone figure out qucikly what is wrong or missing?
automeatedreason
ps.: other weird things happening are:
- the Ad-hoc mode switches automatically to Managed mode after breaking an established connection.
- i often get crashes when i leave the browser (any) with connected wlan
