HELP wanted : how to get my pc internet via bluesoleil usb donkey on my p910
1 replies · 2,199 views · Started 06 August 2006
Hello,
does someone has pc internet on his p910 with a bluesoleil usb donkey ?
Any help will be appreciated I have read a lot of forums and tried couple things.
I DO HAVE INTERNET WITH THE BASE WITH OPERA MINI.
thank you
Hi
I done this last year using that USB dongle but with bad results.
Distance was rubbish.
Would not reconnect when link lost. so by the time I just moved out of range I would have to revisit PC and reestablish connection! 😞
This (donkey) is an ass!! hehe. Software also clashed with Outlook 2002 so I could not run Outlook when using it! All in all crap!
If you're within 10ft from your PC then it is cool to surf wireless and high speed!
If I had the cash I would maybe look at a 990 which should link direct to your wireless Router without the need for your PC to be turned on and maybe work from any room in your house!
Getting it working was troublesome, but if you still do want to then I'll try & take a look and post some notes!
:icon4:
