Can't delete themes from N73
21 replies · 46,093 views · Started 07 August 2006
Hi, I just got my new N73 yesterday, and downloaded some themes for it today, and installed them, but I can't delete them now. I can find them in the themes section but theres no option to delete, and when I use my data cable I can't find them anywhere.
In fact , there are two way to solve the problem,
1. delete the themes files in you mobile. you can install a software such as AppMan in your mobile and then delete the theme files that located in the directory e:\system\skins\ .
2. you also can delete it by useing card reader , but you must change your computer setting --- show all hidden files and all system files.
All you need do is select another theme first so the one you wish to remove is not in use. Then go to App manager on the phone and choose remove. Thats it.
Yes use AppManager rather than manually deleting files - it'll upset the phone if you do this.
hi, i got the same problem w/ my n73, some themes i installed on memory card are in the list of Themes under Tools but they're not in the Applications Manager, cant find way to delete them. any help pls.. thanks
You cant delete it through ybrowser but u can delete it via mass storage mode just make sure show hidden files is on on ur computer connect ur phone to pc select mass storage mode click on private folder open it look for folder named 10207114 click on it and then click import folder u will see the themes folders just select the one u want to delete press c thats it...wont harm the phone, as i encountered the same problem once
thanks, i tried it but unsuccessful. connected my phone to pc & selected mass storage mode, but it says on my pc, "Nokia N73 connected in non-compatible mode" .... also, on my phone display, the "mass storage mode" wont disappear w/ the progress bar moving for several minutes, so i disable the connection... another thing, where do i click the private folder, on my phone or pc? ....... could these themes uninstallation problem the reason why my Application Manager opens after 10-15 mins?.... thanks again..
im sorry, it's not 10-15 mins, my application mgr opens after 10-15 seconds.... my other folders open instantly... thank you
fegunio wrote:thanks, i tried it but unsuccessful. connected my phone to pc & selected mass storage mode, but it says on my pc, "Nokia N73 connected in non-compatible mode" .... also, on my phone display, the "mass storage mode" wont disappear w/ the progress bar moving for several minutes, so i disable the connection... another thing, where do i click the private folder, on my phone or pc? ....... could these themes uninstallation problem the reason why my Application Manager opens after 10-15 mins?.... thanks again..
When Transf Mode is activated the moving bar stay on screen phone. Is like this!
[QUOTE=fegunio;277836]it's done. i found it, was able to delete the themes. thank you so much...[/QUOTE
Hi.
Please could you send me by mail all the procedure to remove the themes. I can't find my way.
My mail is: funnynoussa at hotmail dot com
Thank you in advance .
Nancy.
Hi.
Nancy.
funnynoussa wrote:[QUOTE=fegunio;277836]it's done. i found it, was able to delete the themes. thank you so much...[/QUOTE
Hi.
Nancy.
Use the search function and you'll find the solution,it's been discussed numerous times.
I followed the instructions from 1 post earlier in this thread for removing unwanted themes that were installed on my E65 memory card. The steps followed were from [GT] - "connect ur phone to pc select mass storage mode click on private folder open it look for folder named 10207114 click on it and then click import folder u will see the themes folders just select the one u want to delete press c thats it...wont harm the phone, as i encountered the same problem once".
This worked for removing themes that were installed on the memory card, however when I went back into the menu in my phone (after removing the data cable from PC/Phone) the themes icon was gone and now I cannot access themes or load any new ones onto the phone and I am now left with the default nokia theme that the phone came with. I cannot understand why removing themes manually from the memory card would affect the phone's themes app/icon, and I have no idea how to resolve the issue.
Please help! I would really like to resolve this asap.
Many thanks
nanosec
Even i was unable to delete the themes myself.
A couple of them appeared on the Apps manager that i removed...but rest remained very much there..
A good way out is reinstall the themes you want to uninstall..Now you will find them on your Apps Manager and you an remove them from there.
I suppose the previous installation data went out of Apps Manager coz i updated my firmware..
Pretty sure this might be a way out, though it entails some unnecessary labour of reinstalling before removing the themes...
i been havin same problem workin with carbide i like to install themes on to my phone to see how they progressin thought id delete them all in one go at a later date but they not in apps manager, so now i stuck with umteen half finished themes, will try to get rid of them in the way suggested in this thread but was wonderin what is the reason for this problem is it just a simple bug.
fegunio wrote:it's done. i found it, was able to delete the themes. thank you so much...
hey..im having the same problem..i wanted to know where you found the 'Private' folder..please mail me at [email][email protected][/email] or else please reply here..thank you..
[QUOTE='-[GT]-;277268']You cant delete it through ybrowser but u can delete it via mass storage mode just make sure show hidden files is on on ur computer connect ur phone to pc select mass storage mode click on private folder open it look for folder named 10207114 click on it and then click import folder u will see the themes folders just select the one u want to delete press c thats it...wont harm the phone, as i encountered the same problem once[/QUOTE]
Thanks a million, you made my day. i was really upset with this stupid theme my friend had downloaded, which i couldnt delete. However today, with the help of your instructions i have successfully deleted that theme. A real BIG thanks to you....:icon14:
