[quote="Zippy172"]
I'm now using my Mitsumi USB BT dongle here at work, on Win2K, with the Cyber Blue 'Blue Manager' quite successfully with the Nokia PC Suite. Hurrah!
[/quote]
Well, I spent another frustrating few hours trying to get my Mitsumi dongle working with XP yesterday - and sadly, I got nowhere as well. :evil: :x
I've now tried pretty much everything I can think of.
Apart from the advice in this thread, I found another old thread which looked promising:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=2999&highlight=mitsumi+usb
So, I've tried using the Widcomm drivers, and I've tried using the Blue Manager drivers, but although I can get the software communicating with my 7650 (moving files both ways, pairing, etc) - I can't get PC Suite to communicate with my phone under Windows XP.
Whatever software or drivers are installed, mRouter just will not see my phone under XP. All of the appropriate ports are installed and working correctly in device manager and they are ticked in the mRouter properties window. But still there is no connection, even though the phone and my computer can communicate otherwise using whatever BT software happened to be installed.
I thought I'd cracked it under Windows 2000 when I got mRouter to see my phone with the Blue Manager software/drivers installed, but then PC Suite just hung on start up. Grr!!
After so much installing and removing and rebooting and re-installing I've reluctantly come to the conclusion that this Mitsumi dongle won't work with PC Suite under XP. My XP installation ended up getting so confused yesterday that I had to uninstall all BT software, then manually strip out any driver files and registry entries relating to anything BT, otherwise I couldn't even get basic file transfers and device discovery working.
So I'll wait for the rumoured new version of PC Suite to arrive, but if that still doesn't work, I'll chalk this up to experience and buy a new MSI or 3com dongle. In the mean time, I've gone back to the orginal Mitsumi software which will at least let me exchange files between phone and PC.
The only other option I can think of is to try using XP's compatibility mode so mRouter and PC Suite run is if under Windows98/2000. But that's a long shot.
I'll also try installing everything under Windows 98 or ME, so at least I can get some kind of backup if anything happened to my phone again.
Don't get me wrong, I think the 7650 is a great phone, but my god it's caused me some trouble over the last three months. :x 😉
