Streaming to my N80 from my remote server
16 replies · 3,849 views · Started 08 August 2006
I encoded a .3gp H.263 video for streaming, and uploaded it to my Linux box. I just can't get it to stream. I've tried http:// via the browser, and rtsp:// thru Real Player -- the first option proceeds to download the file; the second gives up with "can't connect".
Is there some rocket science here that I'm missing? Maybe a server-side problem or something?
All help very greatly appreciated!
Thanks!
aZooZa wrote:Hi,
Thanks!
I Think that somebody has discussed this here before, did you do a search, you may get your answer quicker than waiting for somebody to respond with the answer.
Cash, I see you've been very helpful here offering people similar advice, and discussing Orb etc. My question is more specific. As I said, I'm trying to connect to a remote Linux server, and to stream a .3gp file to my N80. This is not Orb on my local network.
I searched for "streaming" in the N80 forum. Results are here:
http://www.allaboutsymbian.com/forum/search.php?searchid=1006917
I can't find a thread where my issue has been discussed before. Maybe I'm missing something?
Connecting to the BBC and other sites which employ dedicated streaming servers like Helix is not a problem for me.
If you can point me to a thread which discusses my particular issue I would be very appreciative.
Thanks!
Thanks Cash. The stuff addressed there isn't part of my problem, but I do appreciate your looking for me.
I think my solution would be for the N80 browser to understand what a .3gp file is and pass it to Real Player instead of the text pad. But nothing's ever simple 😞
Thanks again!
have you set the network settings in the real player first before you try streaming, also what firmware do you have, there was a problem with streaming and realplayer in the old firmware that was sorted in the new firmware
Yes, I have network settings configured to talk to my WLAN. I have firmware:
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (58.01)
Is this the firmware with the problem?
one other thing you may try, is your firewall configured correctly, I had this problem with orb that zonealarm didnt auto configure access, or warn me to configure, after I configured it worked ok
Maybe worth having a look at
just going through all the problems I had with steaming when I first tried😊
I think I'm right in saying that streamed files are different to standard files. I may be wrong, but I was under the impression you needed something specific on the server? (i.e. you need to set up a streaming server). Might be worth a look on the Helix wesbite to see if you can get more on this.
I think that's it in a nutshell Rafe, after another 6 hours wasted today messing with various encoders. Will try and find a webhost that offers a streaming service. If anyone knows of one, I'd be pleased to know, as I don't want to have to buy a complete Helix server just to enable video, for what is for me a small mobile audience.
Thanks!
Actually, I spent many hours yesterday trying to find a single video file on the internet that would stream to my N80. Nothing. Does anyone know of a working, streaming video link?
Thanks!
I never actually got any to work either, but there are some out there because I read that some people have done this, I know sites that use flash to stream wont work, and I think that sites that have the video embedded in their websites wont work either.
The only streaming I have managed to do is with orb and streaming from my computer.
Orb do have a test site so that you can check your N80, I have streamed from there
http://test.orb.com/streamtest/home.jsp
