n80 flashing confusion
16 replies · 4,812 views · Started 08 August 2006
I'm looking to replace the firmware on my Orange N80 with the standard unbranded one.
I've seen the site with the instructions, but there are loads of different files in the N80 folder:
N80_RM-92_APAC_PR_dp_v12.00_SW3.0617.0.6.exe 09-Jul-2006 01:42 83M
N80_RM-92_EMEA_PR_dp_v12.00_SW3.0617.0.6.exe 09-Jul-2006 01:44 108M
N80_RM-92_EMEA_PR_dp_v12.01_SW3.0617.0.6.exe 09-Jul-2006 01:47 62M
N80_RM-92_EMEA_PR_dp_v12.02_SW3.0617.0.6.exe 09-Jul-2006 01:49 73M
N80_RM-92_EMEA_PR_dp_v12.03_SW3.0617.0.6.exe 09-Jul-2006 01:49 24M
RM-92_APAC_PR_dp_v12.03_SW3.0617.0.6.exe 09-Jul-2006 01:50 9.3M
RM-92_EMEA_PR_dp_v12.02_SW3.0617.0.6.exe 09-Jul-2006 01:54 73M
RM-92_EMEA_PR_dp_v12.04_SW3.0618.0.2.exe 09-Jul-2006 01:54 58M
RM-92_EMEA_PR_dp_v12.05_SW3.0617.0.6.exe 09-Jul-2006 01:55 9.3M
I can't find anything to say which is what. I guessed that v12.03 (5th down) would be what I'm after, but then I noticed it was 24Mb compared to 108Mb for v12.00.
Can anyone put a stop to my confusion?
Cheers.
Thanks Cash. I have the files now. Just waiting for my brother to come over so we can do them both at once.
Slightly confused by the V08 etc bit. Are these versions just different language packs? Or does it need to match where the phone came from?
My current firmware is:
V 3.0617.0.6
RM-92
Nokia N80 (31.01)
these are just language packs, the main firmware is one of the other files in the download, I am english and have v01, I also believe V08 also has english.
here is a point in the software installation where you have to apply the crack, you have to do this in a split second or the crack misses some of the files and you will need to install the pheonix software again and try to crack it faster.
Also when you are installing the firmware to the phone it may ask you if you want to continue a couple of times, just press yes and it will be fine.
Dont forget though that you will be voiding your warrantee when you upgrade them yourself.
And you are doing it at your own risk ..
My only concern was that it would be American English and not British and that some of the dictionary words (color, organize) would be American.
I know it's at my own risk and voids the warranty - but from what I've read they don't much care when you send one back faulty.
Herbs wrote:My only concern was that it would be American English and not British and that some of the dictionary words (color, organize) would be American.
With V01...when I spell colour it spells it the correct way ... that is colour...the british way 😊
Sorry guys from US .. just having a little friendly dig 😊
Thanks again for the reassurance.
I'm on my third attempt at installing Phoenix and the crack. Although I'm installing the crack, and overwriting files as soon as I've clicked the retry button, it fails eventually telling me there's no DESkey (dongle?).
I'm going to keep trying, if anyone has any tips I'd be grateful.
Herbs wrote:Thanks again for the reassurance.
You have to be really really quick when clicking the crack .. lighteneng quick .. really ..took me 4 times to get it right, and 3 times the second time when I did my mates phone ..
Herbs wrote:I'm looking to replace the firmware on my Orange N80 with the standard unbranded one.
Cheers.
SAme question as the guy above. No one really answerd buy just pointed to diff threads about on how to flash the phone. I was wondering whats EMEA? APAC? can anyone tell me how to read the filename? (e.g N80=phone,RM-92=model version, etc...)
btw is RM-92_EMEA_PR_dp_v12.04_SW3.0618.0.2.exe the latest version? since its 3.0618?
Btw my phone has
V 3.06143.0.3
RM-92
Nokia N80 (12)
Which of the following firmware (listed on the guys question) do i use? As lon as it has american english in it Im ok with it. Thanks!!!
jonsimbulan wrote:SAme question as the guy above. No one really answerd buy just pointed to diff threads about on how to flash the phone. I was wondering whats EMEA? APAC? can anyone tell me how to read the filename? (e.g N80=phone,RM-92=model version, etc...)
Btw my phone has
V 3.06143.0.3
RM-92
Nokia N80 (12)
The 3.0618 firmware is "3" network firmware, so stay away from it unless you want all the "3" crap, the latest Generic firmware is 3.0617...use that.
where it has the V12.01 for example, I think the 12 is the region i.e. europe, or asia, the .01 is the language contained V01 and V08 are western Eropean and include british english.
Go here and follow instructions, its quite easy and simple to do http://www.allaboutsymbian.com/forum//forum/thread/46864/, I am English and have V01 in my phone, because its the generic firmware it the version doesnt show like v12.01, it just shows as v01.
Thanks . I think I get it now. Whats APAC and EMEA and why is there a big diff in size? Do I have to install one before the other? i.e install the 108MB file first before the 24MB?
Got this from mobileburn:
V01 Euro 1 / Alps / France
V02 Euro 2 / South Africa / Turkey
V03 Scandinavia
V04 Baltian
V05 Moldovia / Belarus / CIS / Bulgaria / Ukraine / Russia
V06 Euro 3
V07 Greece / Cyprus / Balkans
V08 Gulf / Lebanon
V09 Romania / Israel
V10 TAIWAN
V11 APAC 1
V12 INDIA / PHILIPPINES
V14 HONG KONG
V15 THAILAND
V20 INDONESIA
V20 (U02) NEW ZEALAND / AUSTRALIA
V31 (U21) Orange UK
V32 MobileOne
V36 DTAC
V37 Globe
V39 Smart
V40 Telenor
V41 Mobitel
V42 VF UK
V46 HK CV
V47 TIM Greece
V48 AIS
V49 SingTel
V51 Vodafone NL
V58 UK CV
V59 Pannon
V62 Turkcell
V69 CZ/SK CV
V70 Indonesia CV
jonsimbulan wrote:Thanks . I think I get it now. Whats APAC and EMEA and why is there a big diff in size? Do I have to install one before the other? i.e install the 108MB file first before the 24MB?
Procedure is all explained in the link that I gave you ..
guido45 wrote:Anyone flashed to this version yet? "RM-92_EMEA_PR_dp_v12.07_SW3.0618.0.2.exe"
Here: http://nokia.dogtoe.com/files/firmware/n80/
I was under the impression that this version does not add anything to the previous version, apart from some network specific stuff for the "3" network, I may be wrong though.
Could somebody confirm ?
