How can i install transparent opertaor logos for my 6600. whenever i install one using SeleQ or FExplorer i get a white background.
also my Speed Dilaling is not working.. i've tried formatting the phone but the problem persists
Transparent Op Logos
I don't think transparent logos work at all. You have to use one that matches the theme background image.
Don't know why speed dialing is not working? Is it turned on (it is turned off by default)?
But whenever i try to start it via the icon in tools.... just a white screen comes n nothing happens
Save all your data and reformat the phone (I bet it'll clear up the speed-dial problem of yours): http://www.allaboutsymbian.com/forum//forum/thread/17507/
I tried that. It had solved the problem but when i restored my backup data, the probelm appeared again. N now the mic doesnt seem to be working.... can i backup only the messages n the contacts n not the whole phone memory..
