How to use the browser in E61
1 replies · 1,982 views · Started 09 August 2006
a new bie from India finds it frustrating going back and forth the manual, Nokia Support and Airtel Support and still am unable to access the internet through the browser.
In the browser, I get an error message called "No gateway" and in the services browser, I get the message that too many connections are open.
What am I doing wrong? tried experimenting fearfully a bit but was not successful.
could someone please help? Thanks.
Jayant
Sounds like an access point problem. Have you got these correctly defined and are you using the correct one in Web (this is set in Web's settings - might be best to use always ask).
You need to use the access point that alows Internet Data. This depends on your operator. If you think there is something wrong with your access points (defined in the Settings -> Connections application/ dialog you should be able to have your settings sent to you (look for the Nokia configurator via Google - the url escapes me).
