Hello,
Does any one know any where where I can get app's , games etc.. for my N73??
david
Hello,
david
HA HA HA HA .. I should of seen that coming a mile away !!!...
Any others?..
David
the ones that I have chose .. the free ones for now .. dont work...I install via the nokia suite etc.. and the N73 says the app is not suported.
David
You need apps for 3rd edition S60 (9.1) often called S60v3. All the trial apps are great to try. If you try hard enough on google you can also locate "other" sources of software but beware... symbianOS viruses are growing by the day so I wouldn't recommend randomly downloading and installing software from untrusted sources. Cheers.
Yeap, try http://www.dotsis.com or http://www.series60v3.com
I hope this helped!:icon14:
Thanks for the web sites, checked after reading your replies, has anyone found any other sites worth browsing?? wouldnt mind trying to get hold of a version of total ir remote compatible with n73
