I find the N70's gallery view a bit restrictive - all that whirling round of the images is slow and the updates for new pics takes a while.
Also, there is no apparent way to show a full screen pic and rotate the image as I used to be able to do on my 6630.
However, if you access the pic direct from FExplorer or similar, it opens up a default gallery viewer (just like the 6630 had) and here you can get full screen with * and rotate with 1 and 3.
The N70 gallery seems to be an enhanced version of Image Manager on the 6630/6680, but there was also the Gallery app too which I found preferable for the reasons above.
Is there anyway of accessing this default Gallery viewer directly and assigning it to the multimedia key, instead of using the whirly round full-on restricted viewer??
Cheers,
Chris
