Hello folks,
I am looking for a 3 UK customer who has the original '3' branded firmware on their phone. I need some help because when I had my phone upgraded to the latest firmware it deleted the Hutchison Whampoa Security Certificate which means I can't install any of 3's downloadable applications.
I simply need you to post (or PM to me) the CACerts.dat file from the operating system (don't worry it doesn't contain anny personal data) it's located in C:\System\Data\CACerts.dat. If you use FExplorer you can then simply send the file to your PC using Bluetooth or copy and paste the file into an accessible folder (like C:\Nokia\Other) then use the File Manager to grab it from the PC.
I am assuming this is all I need to get the certificate installed, if anyone knows any better, let me know!
Many thanks to anyone who will do this for me.
Cheers,
Seb.
