phone memory query
2 replies · 1,296 views · Started 09 August 2006
when i use file manager > memory details it tells me:
13mb mem in use
34mb free memory
5kb calendar
90kb contacts
10kb messages
0kb images
0kb sound files
0kb video files
4kb documents
ok, so 109kb "in use" even though it tells me im usin 13mb.
any idea what the 13mb in use actually is?
Wirelessly posted (NOKIA 6630: NokiaN80-1/3.0 (3.0617.0.5) Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
its being used by apps that r on fone, for example, if u get a unlocked/generic n80 then apps like adobe/quick office etc can b removed but with say an o2 branded n80 sum 3rd party apps cant b removed! u cud try a format, type *#7370# into the standby screen! NOTE: this code DELETES all info u have put on ur fones memory including contacts, notes etc, ur mem card is NOT effected!
