how to copy all contact into SIM?
6 replies · 2,398 views · Started 03 December 2002
i think that your sim only supprts a name and a number
so if u have multiple phone numbers and info under a single name (teleohone, mobile, email) then this wont work right
Why not try it,after all,if it does not work (I think it will,but only on the 7650,or it might not) you can allways delete the contacts from the sim.
Well basically, it should work on most nokia phones But it don't work on 7650. Reason, simple... The data format on the sim and memory of 7650 are totally different. And that's why you can not copy direct to the phone to sim card. Unless you copy one contact at a time.
Although true, the T68i makes more than 1 contact on the sim if u have more than 1 number for the same person. Shame Nokia didn't think of this
never mind......what i wanna do is actually backup my contacts since i am considering to go to NSC for firmware upgrade. I just use Outlook to backup then
