Hello everyone,
I have a problem with my memory card and nokia N70 (not corrupted memory card, but corrupted file). Last night I tried to install a file named: "Shape service keypad+" to my memory card. The phone hanged between installation. I tried to restart the phone and the phone restarted again and again. I removed the card from the phone and restarted the phone, the phone booted without a problem. Now i want to remove those files (which came with the installation) from the memory card. I don't own a card reader so I decided to use Fexplorer to remove those files from the card. I turn on the phone and after the phone boots to standby screen, I insert the card, but as soon as I insert the card, the phone tries to load the startup files from the card, then the phone hangs again. I tried even to boot in the safe mode ( by holding the PEN, please correct me if it is not correct) while the card inserted, but the phone can't boot up with the card even in the safe mode. My question is: Is there anyway to insert the memory card in the phone (after successful startup of the phone), without loading the startup files which located on the memory card? so I can remove the files using Fexplorer.
I appreciate your help.
