Mini WIFI sd cards on N73?
4 replies · 36,403 views · Started 10 August 2006
this is all very well and good, but do you realise they dont actually have any memory in the card, its just a wifi card.
i dont see why it wouldnt work though, but it would mean you could only use the phones internal memory.
chr155cott wrote:this is all very well and good, but do you realise they dont actually have any memory in the card, its just a wifi card.
you use it only when you want wireless internet,you take out the memory sd and put this in when you go to a wifi spot!!!
The N73 does not support SDIO, for sure. (And even if it did, it wouldn't have the required WLAN sw, so you would have to get that from the card vendor along with device drivers, too).
