iv only had my N80 for 1 week, and i have a few questions that i hope some one can help me with. i have searched the forms and cant really find the answers.
question 1.
when will we start to see more 3rd party software for the N80?
question 2.
does any one really know how to hide files from the dreaded gallery?
(iv looked in many places for this one)
question 3.
when and if the new 4.XXX firmware is released how do i update?
question 4.
does any one know how to add short cuts to the Go to menu?
any help or directions would be really great.
thanks
Hi Broadbent
1, Developers are working on apps all the time, and new ones are coming out everyday, you just have to look for them, and be patient, there are many links in this forum and site to find software that runs on the N80
2, You cant hide files without some third party software, I think hand safe will do this, someone may give more advice on this
3, Not sure about how to update, but I think it would be in exactly the same way as the last method, or take your phone to Nokia service center
4, What is the goto menu..I probably know it, but by a different name, My manual is in Lithuanian and I cant read it, and didnt bother to download an english version yet, and I get most my tips and advice from this forum.
Hope that helps in some way
check out
guide clicky click click
software download clicky click click
havn't done it myself but general consesus is it works 😊
Hope it helps
EDIT : If anyone can find a way of hiding music from the player, that would be great. I hate the way it plays my ringtone 😞
Thanks!!
Cash wrote:4, What is the goto menu..I probably know it, but by a different name, My manual is in Lithuanian and I cant read it, and didnt bother to download an english version yet, and I get most my tips and advice from this forum.
Thanks for the help on the other questions. as for the "goto" menu it is the blue diamond in the "my own" menu.
thnaks for the help you truly are a ledgen:icon14:
llolslim wrote:check outguide clicky click click
Hope it helps
Thanks!!
This does work but with SExplore but like the guide says. dependant on the phone memory. also but creating a file in the memory card, this does not work...
thanks for the help
as for the music you might be able to hide it using the same method as the guide above.
broadbent30 wrote:Thanks for the help on the other questions. as for the "goto" menu it is the blue diamond in the "my own" menu.thnaks for the help you truly are a ledgen:icon14:
Haha..Oh yea 😊..it has goto written under th icon ...I need to learn to read 😊..
so do you know how to add other short cuts to it...
thanks
broadbent30 wrote:so do you know how to add other short cuts to it...thanks
I dont know myself..I dont use this
Have a read in this thread
http://www.allaboutsymbian.com/forum//forum/thread/49752/
