Hi
Just a few questions...
Can the N93 definately play Ngage games?
Also can you install blz files to play ngage freeware games?
in actual fact can you install any apps at all, anyother installers?
if so how?
Thanks 😊
Hi
if so how?
Thanks 😊
Short answer no.
Long answer: Nokia N93 is based on Symbian OS 9.1 while Nokia N-Gage is based on Symbian OS 6.1. Both operating systems are not compatible at all. All the native N-Gage games won't work in N93. There may be some Java games that may work, but they may occupy part of the screen because of screen resolution difference.
antonypranata wrote:Short answer no.Long answer: Nokia N93 is based on Symbian OS 9.1 while Nokia N-Gage is based on Symbian OS 6.1. Both operating systems are not compatible at all. All the native N-Gage games won't work in N93. There may be some Java games that may work, but they may occupy part of the screen because of screen resolution difference.
Even more longer: ... and to work they must be compiled for S60 v3😉
