Composing ringtones
8 replies · 1,955 views · Started 03 December 2002
On the 3330 you can press ceratin keys in order and input ringtones.
Does anything like that exist for 7650 or do I have to know the notes to input a tone. As I am not all that musical, I wouldn't know how to input all the correct notes, tempo, rests etc.
Is there a way to input the tones in order e.g. 1-3-4-5, would give you the first notes of When The Saints.
Find the program for inputting tomes harder and so wondered if there was a site or two that would show what keypresses to press.
Well, you should be able to find an easy to use midi composer for PC.
After composing, you could send the file to your 7650.
Just open the composer from the menu and select new tone! Press the number keys and the notes will be added!
I have a 20s wav clip from a CD that I want as a ringtone but it is way to huge to put across on teh phone. ANy workaroud for it or how to convert it to something smaller?
Tried AMRConverter (the GUI one) but the converted AMR file is not nice at all.
Found that if you open up the WAV file in Sound Recorder (\Windows\System32\sndrec.exe - in XP) and then click File | Properties you can convert to many different formats. 3MB file went down to 400 kB!
Thanks for the suggestion!
