http://gallery.mobile9.com/c/nokia-n80-themes/1/
This page says the themes are for N80 but they dont work. Can anyone explain the .sis thing.
Can anyone tell me where to get themes taht work or what i need to do with them.
those themes do work i have some myself, you need to use the nokia pc suite to intsall the sis files onto your phone.
1. connect phone to pc and open nokia suite
2.click on install aplication and find the sis file on your pc
3. go into themes and it should be there
hope that helps
Yeah thanks that helped, im just confussed with all the .sis stuff soem works and some dont. And sicne the phone wannt connect to PCsuite for some reason i have only tryed to download them from wap.
So this clears every thing out. Thanks !
Themes, search here: http://symbian.mobilethemes.com/
