Compressing/converting movies to watch on e70 question
22 replies · 9,200 views · Started 11 August 2006
I recently got a Nokia e70 and want to compress some movies to the size of the display to take up less space. My buddy had an iPaq and did this and used a program to make them smaller than 128mb and landscape widescreen with good resolution. Just curious what programs are out there and prefer free.
Thanks!
N/A wrote:Search for SUPER by eRightSoft
Okay, I have the software... now how does it work? What format am I looking to convert to and how do the settings need to read?
jeremyhelling wrote:Okay, I have the software... now how does it work? What format am I looking to convert to and how do the settings need to read?
I think I've got it figured out here. I just need to fine tune the settings on it. Thanks!
There are a number of posts on SUPER setting in this forum. A lot depends on what you are converting from, but generally you want to go into the H.263 format.
Thanks Rafe. I did some searches before creating this thread and yeilded little. Now that I know what software to use I'll try some more searches using that term. Thanks!
Rafe wrote:There are a number of posts on SUPER setting in this forum. A lot depends on what you are converting from, but generally you want to go into the H.263 format.
I re read your post and H.263 for video w/AAC for audio is what I'm using but I was wondering more about the other settings to achieve the best PQ w/o taking up too much space since size is also an important consideration.
Also, what would be the best format to convert my ISO DVDs into first since SUPER doesn't seem to like converting ISO to H.263?
try to use xilisoft video converter 3.1
its not free. but u may use the trail version first. its powerful.:icon14:
evanstar wrote:try to use xilisoft video converter 3.1
What does it do that SUPER does not?
im not familiar with super. but i know that xilisoft video converter can convert almost all formats files.
What does SUPER do that XiliSoft does not?
evanstar wrote:im not familiar with super. but i know that xilisoft video converter can convert almost all formats files.
It's free. And it can convert pretty much every format too. Maybe the only thing it can not do is convert direct from a DVD or CD.
That's pretty much what I was wondering since SUPER is free and seems to be pretty powerful. Just wondering why I would want to pay for something and what it can offer me above what the free option does.
jeremyhelling wrote:That's pretty much what I was wondering since SUPER is free and seems to be pretty powerful. Just wondering why I would want to pay for something and what it can offer me above what the free option does.
A lot of good remarks about SUPER. I gonna try one of these days.
Wirelessly posted (Nokia E61: Mozilla/5.0 (SymbianOS/9.1; U; en-us) AppleWebKit/413 (KHTML, like Gecko) Safari/413)
Super is a lot more flexible than Xilsoft or Imtoo - and its free.
For fast conversion, Smartmovie is hard to beat.
Regards, Michael
I'm having great luck with SUPER so long as I enable 'DirectShow' and rename the ISO to MPG for ripped DVDs. The only problem is that the volume is pretty quiet using this method where other MPGs I've converted are plenty loud. Hmmm...
Smartmovie is one of the few converters I have tried, that allows you to boost the volume. just set it to 150% before the conversion.
egards, Michael
yeah, Super is a lot more flexible caz many paras available, i have the apperence of SUPER. but i think it's not easy to use.
jeremyhelling wrote:I recently got a Nokia e70 and want to compress some movies to the size of the display to take up less space. My buddy had an iPaq and did this and used a program to make them smaller than 128mb and landscape widescreen with good resolution. Just curious what programs are out there and prefer free.
Thanks!
Try to use yasa 3gp video converter. It works great. however it is not free.
http://www.yasasoft.com/3gpvideoconverter/
There's also CloneDVD Mobile (with trial), which has presets for 3gp. Not sure about the quality though -i'm pressing Spun to .3gp with the preset setting at the moment.
I'm bumping this thread because I wanted to update it for those that might also be interested in how to do this. Here's a link to a thread I started with some more details on what worked for me.
