go to icon
1 replies · 1,382 views · Started 11 August 2006
Does anyone know 'how-to' add/remove icons in Go To?
Currently, it has Calendar, Inbox, & Notes
Many thanks,
Nicholas
You can't remove preinstalled things there.
You can only add things there, if the app has specific support for "Go To" (in which case you will find an option for that in the "Options" menu of that app). Most apps have no "Go To" support whatsoever.
I think Psiloc (or somebody) wrote an utility for older (S60 2nd Edition) phones to put any app there.
In general, I just used to move the whole "Go To" app to the bottom of one submenu or another, and avoid it entirely.
