Transfer from v2 to v3
2 replies · 3,615 views · Started 12 August 2006
Wirelessly posted (Nokia6680/1.0 (3.04.11) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
I was wondering if the transfer function in my 6680 will work with the n93 considering they are using different versions of symbian.
Cheers.
Yes! It will provided you use the transfer app on the N93! This will install an app on the 6680 and it'll work just the same!
I did exactly the same and worked a treat with my 6680 and N93!
