Can not make .SIS file
0 replies · 7,280 views · Started 13 August 2006
It had show this report
MAKING DESCRIPTOR FILE
SUCCESS!!
MAKING SKIN PACKAGE
C:\Program Files\Series_60_Theme_Studio\S60_TS_3_0\bin>ECHO OFF
ECHO is off.
123456createskin = true
install_dir = C:\Program Files\Series_60_Theme_Studio\S60_TS_3_0
source_dir = C:\DOCUME~1\VERSAR~1\LOCALS~1\Temp\Girl
dest_dir = C:\Program Files\Series_60_Theme_Studio\S60_TS_3_0\bin\..\data\skinsdir\Girl
skin_name = Girl
system_selection = false
drm_selection = false
normal_selection = true
public_key_file = C:\Documents and Settings\Versarius\Desktop\Temp\versarius.key
certificate_file = C:\Documents and Settings\Versarius\Desktop\Temp\versarius.cer
public_key_file_name = versarius.key
certificate_file_name = versarius.cer
itmid_file = noitemidlist
screensaver = null
screensaver_name = null
screensaver_uid = null
version_selected = 2.8
CREATING SKIN FILES
CREATION WITHOUT ITEMID LIST
Skin Compiler v1.64 (Jun 21 2005/2.8) for Series 60 Platform.
Copyright (c) 2003,2004 Nokia. All rights reserved.
Phase 0: Parameter summary.
Source file: Girl.txt
Skin name: Girl
Phase 1: Input parsing.
Opening source file Girl.txt ...
Parsing file ...
Completed.
NOTE: Skintype: Normal
Phase 2: Output for MBM/MIF generation.
Writing MBM/MIF list for Girl to Girl_MBMList.txt ...
Completed.
Phase 3: Output for skin content.
Skipping CPP and MMP file creation (non-system skin).
Writing SKN file (that uses MBM/MIF Girl) to Girl.skn ...
Completed.
Writing PKG file for Girl to Girl.pkg ...
Completed.
Completed successfully.
CREATING MULTI BITMAP FILE
BMCONV version 113.
Compiling...
Multiple bitmap store type: File store
Epoc file: Girl.mbm
Bitmap file 1 : .\qsn_bg_area_main_idle.bmp
Bitmap file 2 : .\qsn_bg_area_control_idle.bmp
Bitmap file 3 : .\qsn_bg_area_status_idle.bmp
Bitmap file 4 : .\qsn_bg_area_status.bmp
Bitmap file 5 : .\qsn_bg_area_main.bmp
Bitmap file 6 : .\qsn_bg_area_control.bmp
Bitmap file 7 : .\qsn_bg_navipane_solid.bmp
Bitmap file 8 : .\qsn_bg_navipane_wipe.bmp
Bitmap file 9 : .\qsn_bg_area_control_popup.bmp
Bitmap file 10 : .\qsn_bg_slice_popup.bmp
Bitmap file 11 : .\qsn_bg_slice_pinb.bmp
Bitmap file 12 : .\qsn_bg_area_main_list_gene.bmp
Bitmap file 13 : .\qsn_bg_area_main_list_set.bmp
Bitmap file 14 : .\qsn_bg_area_main_apps_grid.bmp
Bitmap file 15 : .\qsn_bg_area_main_message.bmp
Bitmap file 16 : .\qsn_bg_area_main_high.bmp
Bitmap file 17 : .\qsn_bg_area_main_pinb.bmp
Bitmap file 18 : .\qsn_bg_area_main_calc.bmp
Bitmap file 19 : .\qsn_bg_area_main_qdial.bmp
Bitmap file 20 : .\qsn_bg_slice_fswap.bmp
Bitmap file 21 : .\wallpaper.bmp
Bitmap file 22 : .\qsn_fr_pinb_corner_tl.bmp
Bitmap file 23 : .\qsn_fr_pinb_corner_tr.bmp
Bitmap file 24 : .\qsn_fr_pinb_corner_bl.bmp
Bitmap file 25 : .\qsn_fr_pinb_corner_br.bmp
Bitmap file 26 : .\qsn_fr_pinb_side_t.bmp
Bitmap file 27 : .\qsn_fr_pinb_side_b.bmp
Bitmap file 28 : .\qsn_fr_pinb_side_l.bmp
Bitmap file 29 : .\qsn_fr_pinb_side_r.bmp
Bitmap file 30 : .\qsn_fr_pinb_center_wp.bmp
Bitmap file 31 : .\qsn_component_color_bmp_cg3.bmp
Success.
WRITING SCREEN SAVER DETAILS
1 file(s) copied.
1 file(s) copied.
CREATING THE SIS PACKAGE
Processing Girl.pkg...
error: cannot open file, check filename and access rights
FAILED while executing makesis.
FAILED !!. Read report given above
How can i correct it
please help me
