Joystick shortcuts to different applications E70
2 replies · 2,393 views · Started 13 August 2006
Hello,
On my E70 home window, pressing the joystick to the right opens the Calendar, upwards leads to the camera, leftward to Text Msg and downward to Contacts. How can I assign different applications to the joystick?
This is done in the Settings application (in the Tools Folder). I believe this is under Device - Display - Idle Screen.
A note for those foxed by this comment - this is with 'Active Standby' set to off. If it's set to on, the joystick on the homescreen acts as a cursor to get you round the screen.
Tim
