Using Default Icons
4 replies · 2,981 views · Started 13 August 2006
I have downloaded a new theme for my N70, the only problem is that the icons have been changed. On my 6600 there was an option in the edit theme to keep default icons instead of using the user defined ones. I've noticed that on the N70 there doesn't seem to be this option :S Does anybody know how I can overwrite these new icons and get the default ones back?
I love this new theme and its a shame that i'm not going to be able to use it just because of dodgy icons.
I'd be very grateful for any help,
Sarah
Yeah i thought that would be the only option, I was hoping there was some way round it. I'll have to e-mail the creator and see if they can help out. Thanks for the reply anyways 😊
Maybe there is another way. Search in N-Gage forum, a thread about N90icons on N-Gage. I have that file on N-gage and work well. I don�t know if it works for N70, but it it works, then is possible to have a theme, always with N90 icons, almost the same of N70 icons.
