Can't create new directory on M2 Disk
9 replies · 5,770 views · Started 14 August 2006
Is there an error message? Did you use the file manager in the phone, or a computer? Have you tried both?
Used file manager, want to create a folder named "Resource" in order to put Chinese fonts, however, cannot create folder with name Resource
Do you get any error message?
Are you sure you don't already have a folder with that name? I do, and I didn't know about it.
Anyway, have you tried creating it from your computer?
albatorsk wrote:Do you get any error message?
I have too! It�s not possible to have the same name - create with another one.
Thanks for the assistant. However, my problem is not yet solved. Let me make myself clear again :
1. I want to create a folder name "Resource" on M2 so that I may put Chinese fonts;
2. I tried to create using both a)File Manager from M600i; and b)File Manager from Sony provided PC Suit;
3. Both methods are not working. Something wrong on what I did? Because, the system will only look for the folder Resource to locate the fonts so that I may read and write Chinese;
4. Or, any other method so that I may use Chinese on M600i?
Thanks.
Please. This is the third (and last) time I ask this: Do you get an error message when you try to create the directory? If so, what does it say?
garyching wrote:Thanks for the assistant. However, my problem is not yet solved. Let me make myself clear again :
Thanks.
If I browse the M2 card in "My Bluetooth Places" I can see two other folders - resource and system. Inside resource is apps - but adding files or creating directories gives a server error and says directory may be read only. Creating new folders (that aren't called resource) at the root of the M2 card is no problem.
