Blank Operator Logo...
3 replies · 20,997 views · Started 14 August 2006
Sorry guy, need some help here. Been trying ways to get rid of my operator logo...
Called the Network service provider but they insist it's not removable. But the fact it's showing the network's logo (like those old school colour operator logo you can download for older phones). Just wondering if there's anyway i can just remove. Thanks a million!
Transparent Operator Logo for use with ANY THEME on your Nokia N73 (other phones not tested) go to this URL:-
w w w.free-ringtones-free-logos. c o m (this site only works with NOKIA phones in the UK!!)
Use the search box to find "BlankOpLogoN73" (without quotes) and follow the on screen prompts, this will basically cost you the price of a normal text.
If you can't find my "BlankOpLogoN73", don't worry, simply create your own using the Logo Creator and turn the whole thing black!, this logo creator is only really for old screen types not colour screens, but the effect is perfect.
Regards
Attachments: Screenshot0007.jpg
Just use oplogochanger....it comes with option of removing logo....later u can retrieve logo also...u can change to any logo u want...its working nice on my n73😉
