Nokia 7650 Bluetooth
3 replies · 1,412 views · Started 03 December 2002
I am gettin the following error everytime i try to conect my bluetooth devices :
Bluetooth:
System error
can anyone help????
Do a hard reset of your phone... it will reinstall all of the system files, and should solve the problem.
If not, take it to a NSC...
One recent problem
I had no trouble with BT in anyway erlier. But after i changed the phone, i can no longer see it in device list when i right click on files in PC, (send to bluetooth).
So, now, to send any file, i have to drag and drop😞 which could get irritating at times.
All other funtions are fine (file transfers, PC Suit connection). My phone's visibility is on. Shows ok in BT neighbourhood. Just the "send by rightclick" problem.
Anyone experienced this before? Any suggestions?
I fixed it after fiddling around a bit. One of them should have worked.
Details here, just in case anyone has the same problem.
I purged the Device from BT Config ( did not have to unpair )
In Accessibility, delete the device. "Only devices listed below to connect" > (Delete device) > Back to Only paired devices to connect.
In Discovery Tab, report only listed Devices> Delete device> then back to report to all BT Devices.
Recycle visibility option on phone
Then, ofcourse, reboot PC
