I have been surfing around a couple of times searched for a VPN client running on S60 without result. I have also tried to find a configuration document for the Nokia VPN inside the phone, but I seems hard to find. In that case I think it should be possible to use that trough our Nokia IP350 platform with Firewall-1 on it, but also there I cannot find any good info to go on with. Does somebody have any ideas/ways to solution?
Vpn
If you have a Nokia VPN gateway, you should also have or be able to get the Nokia Security Service Manager software to create the required policy files for the Nokia Mobile VPN client software.
well yes, my idea was that that should work but there is no simple way and what does Nokia mean with Nokia Security Server. I haven't seen some good product descriptions for it and there is no configurations documents I can find... = I litle bit frustrating -> and that's why I think it should be easiest with a simple VPN client on S60 but now I cannot find any. Ealier I have understand there was a client called MovianVPN but I cannot find any company selling this or have a evaluation for it.
