Camera buttons lag time
3 replies · 1,803 views · Started 14 August 2006
Picture taken with Navibutton - 6 second delay, back to camera mode
Picture taken with side button in landscape - 12 second delay with "Saving image" stripey progress bar then back to camera mode.
Twice as long.
Is everyone else's the same?
Any reason for this?
:con?
Chris
Same to me. Before this beauty I had a 3230 which made the capture after
around 8 seconds, now that was a lag. On the N70 the lag is bigger if you
make the photo by pressing the side button because the image is edited
(rotated). Make a test: take the same picture by pressing the Navi and the
side key. Download the pictures in a PC and see the difference.
ratza wrote:On the N70 the lag is bigger if you
(rotated).
I see now - never realised the rotation happened then.
Cheers!
