I am a N70 owner new to Symbians.
I have purchaesed a Transcend 1GB Dual voltage card which is functioning well.
I attempted to copy the content of the Nokia supplied 128 M card 1st to my PC and then back to the 1 GB card which I 1st forwarded in the phone.
Copying was done via an extenal reader from card to PC and then via the USB cable and Nokia phone browser from PC to phone as my external reader didn't like the 1GB card. All programs seem to have been copied back and everything looks viewing using FExplorer but when viewing using the phones File Manager or via the Nokia SYSTEM folder is not visable. Any idea why?? :con? :con?
New Memory card
Any folder which has the hidden and/or system attribute won't be visible in Gallery or File Manager. If you can't see the system folder with FExplorer 1.16, go to Options->Settings->System/Hidden files and select on.
ratza wrote:Any folder which has the hidden and/or system attribute won't be visible in Gallery or File Manager. If you can't see the system folder with FExplorer 1.16, go to Options->Settings->System/Hidden files and select on.
Agree. And the PC must have also "show hidden files" on Explorer.
