Installation Woes
1 replies · 1,630 views · Started 15 August 2006
When trying to install a number of applications, I recieve the message, " replace v1.00", all would usually be fine if I had a version of the application installed previously, but I dont.
I think it could be in relation to Zipman.
Its a pain because I cant install all the files I want to, but have to replace a certain app or game.
It doesnt happen with all installations, just certain ones.
Does anybody have a remedy or experience said problem?
Maybe it happens with apps using Psiloc or Openbit, because such apps use certain background license management/copyright protection mechanism.
For example, if you have installed one Psiloc app, it probably hss installed some shared code/apps that another Psiloc app might also attempt to install (even if the actual app is a different one).
It'd help to determine if this is what happens in your case, if you listed what apps Application Manager shows already as being installed, and wich apps give you this installatio message.
