9300 disconects and reconnects on pc sync
6 replies · 1,660 views · Started 16 August 2006
hi there,
i seem to have a problem . one of my nokia 9300 with version 5.55(01)
seems to have a problem when i connect to the lasets pc suit ...
once i connect the phone it says ( nokia 9300 connected via cable ) and 2 sec latter it disconnects and reconnects ... its on going problem .
i checked different cables ... and tried different pc suit versions ...
i cant tell if its the pc's software or if its something else ...
the Connection at the bottom of the phone is clean ...
maybe its Service Pack 1 ? error ?
please get back to me on this problem ... id appreciate it,
I see the same thing with my 9300 and chalk it up to horrible connector design. There is far too much flex to the cable and its size/weight, compared to the phone, almost forces it to wiggle.
I love this phone but PC Suite and cable is total crap after using a Motorola MPX220 for 18 months (with cradle).
1TWO1 wrote:once i connect the phone it says ( nokia 9300 connected via cable ) and 2 sec latter it disconnects and reconnects ... its on going problem.
I have found this with different USB cables. I have found that the most consistantly good connectors are the ones which have the wire connected to the pop port connector end in the centre - http://shop.nokia.co.uk/bin/venda?ex=co_disp-view&invt=0279054&bsref=nokia - The ones which are ofset are not so good - http://shop.nokia.co.uk/bin/venda?ex=co_disp-view&invt=0277941&bsref=nokia
Don't know if there's any logic to this at all, but it seems to be true IME.
You can also use the cradle, of course - do you get a better connection if you do this?
Tim
hay . i checked a different cable the cable for the n70 works on the 9300 aswell
but on the pc im using the cradle
and seems to connect and disconnect.. every 2 sec ....
does not stop...
i installed service pack 2 .. same problem ... but it was working fine 1 week ago
any idea's
i tried it on another pc and it worked fine
Try installing the latest PC Suite 6.8, I had similar problems in 6.7 After downloading the latest one, it automatically dissapeared.....:con?
