Nokia 6630 slowed down....!
4 replies · 1,509 views · Started 18 August 2006
[FONT="Fixedsys"]Hi Dudes! I need your help recently my Nokia 6630 64 MB MMC Card was not detected and I purchased 512 MB Card...Now the problem which I am facing is my phone is slightly slowed down....When I send message it takes 3 or 4 seconds more...Song some times stops for a second and then starts again....and when I write sms sometime nothing is displayed on the screen then all what I had typed just get typed with lightening speed...also when I receive a call and my .mp3 ringtone starts it also sometimes stops for a second and then it continues....Is this problem serious...It never happened....
I want to know the reason of these delays...! Help! My phone is having 336 MB Free.... 🙄 [/FONT]
exhilway wrote:[FONT="Fixedsys"]Hi Dudes! I need your help recently my Nokia 6630 64 MB MMC Card was not detected and I purchased 512 MB Card...Now the problem which I am facing is my phone is slightly slowed down....When I send message it takes 3 or 4 seconds more...Song some times stops for a second and then starts again....and when I write sms sometime nothing is displayed on the screen then all what I had typed just get typed with lightening speed...also when I receive a call and my .mp3 ringtone starts it also sometimes stops for a second and then it continues....Is this problem serious...It never happened....
Maybe you have plenty of applications installed. do you have antivirus running in the background? it will slow down your phone as well. If i were you i will uninstall unimportant applications.
thepawn wrote:Maybe you have plenty of applications installed. do you have antivirus running in the background? it will slow down your phone as well. If i were you i will uninstall unimportant applications.
Agree. Or a very slow card... Because a 512Mb is not reason for that. Nor even a 1Gb card.
goto log settings and make your log duration 1day only and if you are using your MMC for massaging, change it to phone memory, :icon14:
