HI GUYS
can anyone tell me from where i can download LICENSE MANAGER for nokia 6600...
i accidently removed it and now i cant install any new applicatiuion.....
License Manager For Nokia 6600
I don't remember for sure whether it is a Psiloc or Openbit thingy that gets installed when apps using their copy protection/license management is used.
You should be able to reinstall it by reinstalling the original app(s) that it came with (I don't think there is a separately installable version available).
You might have to uninstall all apps (at least those depending on it) first.
thanks ... it worked
