i am new to this forum. i just got my nokia. i got a new case. there is a problem with my phone which appeared yesterday. i put my phone on charge and it said something like not charging. i am kinda worried. did it happen to anybody and if it did what is the solution.
charging problem
If the voltage is the correct, and the battery is well installed, shoukd work. If not, then is hardware problem, phone or charger or even both. Isn�t frequent, but could happens.
nj7 wrote:If the voltage is the correct, and the battery is well installed, shoukd work. If not, then is hardware problem, phone or charger or even both. Isn�t frequent, but could happens.
it just happened yesterday. i installed my new housing and some softwares. after some time i tried to charge it and the message appeared.
Verify the environement of charge. The place you plug the charger, change for another on the house, where other devices works.
killakam990 wrote:i am new to this forum. i just got my nokia. i got a new case. there is a problem with my phone which appeared yesterday. i put my phone on charge and it said something like not charging. i am kinda worried. did it happen to anybody and if it did what is the solution.
FREN , test your battery first in other fon den charge it thier, when it charged test it again to your own fon so that you can confirm if it is realy your battery or charger has the deffect..
if u've confirm that ur charger and battery is ok den thats the time u open your celfon with T-six tools, it looks like scewdriver, den try to clean the contacts on your celfon board using eraser.. sometimes it happens at our keypod, it malfunction becase of dust... whats your unit by d way
